1. Tap Armoury Crate.
2. Tap Console > scroll down to Button tap force level under AirTriggers.
3. Move the slider to or tap the left AirTriggers button with the force level you want, then tap Next.
4. Move the slider to or tap the right AirTriggers button with the force level you want, then tap Apply.
5. Test the new force level you have set. If you are not satisfied, tap Reset to go back to set it again. Tap OK when you are done.
