FAQBot
Rising Star II
1. Shut the power of phone/tablet immediately and remove battery if it's removable, and also remove power cord if it's connected.
2. Wipe out liquid on the screen/case of phone/ tablet with clean paper towel.
3. Tilt the phone/ tablet at sink so the liquid remained in the phone / tablein is able to run out.
4. Wipe the phone/ tablet again with a clean paper towel.
5. Leave the phone/ tablet to dry for at least 24 hours.    Note: NEVER dry the phone/ tablet  with hair dryer since the heat could possibly deform the case.
6. After the phone/ tablet has been dried properly, connect it to power source and try to turn it on again. If the phone/ tablet is still functioning, please backup all your important files/data.
7. Whether the phone/ tablet is still functioning, we strongly recommend you contact ASUS Service Center and arrange an inspection and maintenance in order to prevent any malfunction potentially caused by oxidation and corrosion.
Version history
Last update:
‎10-14-2019 02:33 AM
Updated by:
