on 10-14-2019 11:05 PM
*Please be aware that after install this system image on a device, all the personal data will be erased, so please remember to back up your data first.
Step 1: Please download the downgrade image from ASUS officail website and then put the image file into the root directory of the MicroSD card.
Step 2: Insert MicroSD card and then power off the device.
Step 3: Long press with"Power" key and "Volume Down" key together for at least 5 seconds to enter Recovery Mode.
Step 4: Please use"Volume Down/Up" key to select menu on the screen. Choose"Apply update from SD card", and then press "Power" key to enter the selection.
Step 5: Please use "Volume Down/Up"key to select the downgrade file and then press "Power" key to make the selection, the process of downgrade will start.
Step 6: When the updating process is done, Choose"Wipe data/factory reset"and tap"Yes" to perform the master clear.
Step 7: Select"Reboot system now" to complete the process.
