FAQBot
Rising Star II
Please follow the steps below to troubleshoot this issue:
1. Go to Settings to check whether “Ringtone & Notification” is not mute and turn up the volume.
Settings">"Sound & Vibration">"Ringtone & Notification"
       2.  Change phone ringtone of the SIM card to check whether it works. “Settings” >> “Sound & Vibration” >> “Phone ringtone”,.
       3. Change phone ringtone of a contact person in “Contacts”. You may select a contact person in Contacts. Then, tap upper-right menu icon to set the ringtone.
      4. Update the firmware to the latest version: You may check the firmware version in “Settings”>>”System”>> ”System updateS” >>”Check now”.
      5. Access to Safe Mode by long pressing power key >>press and hold Power Off >> press OK.
          If your phone works well in Safe Mode, there may be some 3rd applications cause this issue. Please reboot your phone and check again if it works well.
      6. Backup your data and perform factory data reset.
If the steps above can’t resolve the issue, please contact ASUS Customer Support Link for further as...
This information may not suitable for all the products from the same category/series. Some of the screen display and operations may be different from the software versions.
Version history
Last update:
‎03-29-2019 01:38 PM
Updated by:
