Intelligent display / Personalization
Easy to check the date, time, battery power capacity, notification ...,etc.
With the new display technology, it adapts to environment and ensure the maximum efficiency. Even if your are not using the phone, you can also show off your style with personalization settings.
Below steps show you how to set up:
1. Select Always-on Panel from Setting menu.
2. Enable Always-on Panel Settings >Tap Clock style
3. Choose the display pattern you want to show. For instance, Click any pattern to have a preview > Click
at right top corner to choose other patterns > Confirm the new pattern and Apply
Note: This FAQ article may not apply to all types/series of phone products. Part screen selections or operation steps may be different, depends on the software version.
