FAQ
Knowledge Base Articles
<Japan only>About FeliCa-compatible devices and detection areas
About FeliCa-compatible devices and detection areasAs of July 2025, the following ASUS smartphones are compatible with FeliCa. Zenfone Series ・Zenfone 8 ※ 2021 release model ・Zenfone 9 ※ 2022 release model ・Zenfone 10 ※ 2023 release model ・Zenfone 11...
FAQBot by • Community Manager
  • 1593 Views
  • 0 comments
  • 1 kudos
[Phone] Update on Game Genie Malfunction and Solutions
[Phone] Update on Game Genie Malfunction and SolutionsYou can follow the steps below for troubleshooting:   Important Note:Please be aware that following these steps will reset all previous settings within the Game Genie app (except for macros). You ...
  • 1712 Views
  • 0 comments
  • 1 kudos
[Phone] How do I put my favorite picture on the Always-on Panel?
[Phone] How do I put my favorite picture on the Always-on Panel? Swipe down from the top of the screen to access Quick Settings > Tap the Settings icon > Display > Set the Always-on Panel toggle to the “On” position and tap it > Then tap Clock style....
  • 1486 Views
  • 0 comments
  • 0 kudos
[Phone] AI Search Assistant
[Phone] AI Search AssistantFrustrated by wasting time searching for specific phone features? Simply use the search bar in settings to find what you need across all apps. Example: To turn on WhatsApp call recording (if you forget where it's located in...
  • 713 Views
  • 0 comments
  • 0 kudos
[Phone] AI Transcript 2.0
[Phone] AI Transcript 2.0 AI Transcript 2.0: Enhanced AI recording notes featuring expanded multilingual real-time transcription, summary generation, and user-defined language translation. Additionally, it offers speaker differentiation for improved ...
  • 1742 Views
  • 0 comments
  • 1 kudos
[Phone] How to use the AI Panning function
[Phone] How to use the AI Panning functionYou can even capture stunning panning shots with advanced AI. It keeps your subject sharp while adding motion blur to the background for a professional look. Just pan your phone to track the subject, and it a...
  • 1564 Views
  • 0 comments
  • 0 kudos
[Phone] How to use the AI Unblur feature
[Phone] How to use the AI Unblur featureAI can help you salvage photos that are blurred due to handshaking. Using advanced AI technology for alignment and clarification processing, the photos will be restored to be clear and natural. 1. Open the Gall...
  • 1490 Views
  • 0 comments
  • 0 kudos
[Phone] How to use the AI Magic Fill function
[Phone] How to use the AI Magic Fill functionSimply click or circle the person or object you want to remove, and it will be erased and the background will be filled in. 1. Open the Gallery app.2. Open the photo you want to edit. 3. Tap on Edit.     4...
  • 1491 Views
  • 0 comments
  • 0 kudos
[Phone] How to enable the AI Voice Clarity feature
[Phone] How to enable the AI Voice Clarity featureSilent ambience, vocal focus.Create flawless immersive videos with noise reduction and enhanced vocal clarity, all powered by AI, giving you high-quality real-time audio capture - with no extra gear n...
  • 1668 Views
  • 0 comments
  • 0 kudos
[Phone] How do I use AI tracking when taking a video?
[Phone] How do I use AI tracking when taking a video? 1.  Open Camera app. 2.  Select AI tracking from mode options 3.  Find the subject you want to track and tap the white focus box on the screen to lock onto it. 4.  Once locked, AI tracking will a...
  • 683 Views
  • 0 comments
  • 0 kudos
[Phone] How can I use the AI Document summary?
[Phone] How can I use the AI Document summary?Select a file in the File Manager app and tap the Summary button to get a concise and accurate summary.*This feature is only available for PDF, DOCX, and TXT files. How do I generate AI document summary f...
  • 1259 Views
  • 0 comments
  • 0 kudos
[Phone] How do I use Google Assistant on Android 15?
[Phone] How do I use Google Assistant on Android 15?Enter a text, voice or picture to complete daily tasks, including setting alarms or sending messages. Please enable Google Assistant settings first.1. Go to Settings > Display > System navigation.2....
  • 4226 Views
  • 0 comments
  • 0 kudos
[Phone] How do I use Circle to Search?
[Phone] How do I use Circle to Search?By drawing circles, lines, or tapping on text, images or videos with your favorite gestures, you can easily select the content you want and instantly search for it. Please enable Circle to Search settings first.1...
  • 928 Views
  • 0 comments
  • 0 kudos
[Phone] How to Set Up Auto-start Management
[Phone] How to Set Up Auto-start ManagementAuto-start management is a reliable and effective tool that helps you control which apps can start automatically in the background. This can improve system performance and extend battery life. If you notice ...
  • 1766 Views
  • 0 comments
  • 0 kudos
[Phone] How do I enable/disable AirTrigger Capture on my phone?
[Phone] How do I enable/disable AirTrigger Capture on my phone?When using the camera, you can enable the AirTrigger Capture feature, which uses the right AirTrigger to assist with landscape shooting, making photo and video capture more convenient.* V...
  • 1346 Views
  • 0 comments
  • 0 kudos
[Phone] How to fix the OTG function issues
[Phone] How to fix the OTG function issuesIf your ASUS phone cannot use the OTG (On-The-Go) function properly, you can follow these steps to troubleshoot and resolve the issue: 1.Check device connection:Confirm that the USB device you want to connect...
  • 2232 Views
  • 0 comments
  • 0 kudos
Top Contributors
