Phone charge/discharge while plugged in
laylay
Frequency of Occurrence: Just happened
Firmware/APP Version: WW-15.2016.1812.505
RAM: 3G
ZF Model: ZC554KL
APP Name:
Rooted: No
Hi there, I just have this weird problem when my battery was in a repeated struggle of charging/discharging while plugged in to the power source (original charger and cable). The same problem persists when I plug in to the laptop. I just replaced my battery 2 weeks ago and charging was fine until this happens. However, when I tried to loosen the part USB cable that connects to the phone (1/4 out, not inserting to the port completely), it charges fine like normal. Is there a problem with the USB port of my phone? Thanks.
rynn_chew
Hi laylay, A few questions to clarify: 1. Does this happen the same when you use other cables or chargers? 2. Does this happen BEFORE the battery was replaced?
