Masalah Wifi dan Bluetooth tidak menyala
griyax1611
zenefone 3 max wifi dan bluetoth tidak bisa di aktifkan , apa solusinya? thanks
Christine_ASUS
Community Legend II
Hi griyax1611
Did the issue suddenly happen or after any firmware/app download/update? Please try to reset Network: Setting>System>Reset>Network settings reset
Also, please try if Wifi and Bluetooth are well function in "Safe mode"
You can also try "the Factory Reset"
Setting>System>Reset>Factory data reset
Please note that once the Factory Reset is completed, all data, apps, settings and personal information will be deleted.
If the situation remain the same, please contact ASUS repair center in the country of your residence: https://www.asus.com/support/Service-Center-All-Countries/
griyax1611
ok, thanks yours information
i want to try
