Why in the world is my zenfone max pro m1 battery drain is like a leaking bucket..
soorajrs22march
I had it.. what is this some kind of joke..? I can't use my phone for even 2 hrs now. A phone which lasted the entire day with full usage.. I used to watch 3-4 films in one single charge.
It shows 5 hrs left but it won't last even for 2 hours. Even if it does for 5 hrs is that all this phone had..? For 80% it gave more than 24 hrs of standby.
I don't know if asus has some kind of broken dictionary or something.. !!! the word UPDATE means to make improvements.. not to make it worse.. really if you can't do it right don't do it.. I mean no one is asking you to..! Everyime u bring out a new update patche something gets worse.. instead of bringing some new features u take away the things which was already there.. it's good to see asus still has a sense of humour.!!
This was a good phone.. one of the best I had.. the battery performance was the highlight.. and u ruined it.. thanku.. really helpful.. now I can't leave my home for more than 2-3 hours because the battery drains without any usage..
Either fix it or give me my refund.. you guys are the one who said about the great battery life. And I am not getting any now.. there nothing wrong with the battery.. it's just your useless updates.. so technically u destroyed the phone...
28 REPLIES 28
ashishsin1997
soorajrs22march
Brother, I don't think it's just because of the recent update maybe your battery need replacement.
Look at my battery stats
siddhant_paral
souradeep
I also updated my phone to 086 version and then the battery drain occured. Within 24 hours i reverted back to 082 version and now my phone is working perfectly fine. I would suggest you guys to roll back to the previous build. There is one irratating thing though. The new fota update will stay in the notification bar unless you want to update it. And finally don't trust on asus and don't update any fota updates in the future. Better go for custom roms.
Where do you get that bro
jithinlal14_jl
soorajrs22march
I dont knw the reason for sure but switching to another launchrr solved the battery problems in this update for me
soorajrs22march
ashishsin1997
https://zentalk.asus.com/en/discussion/35387/why-in-the-world-is-my-zenfone-max-pro-m1-battery-drain...
I don't know man.. but everything happened after this update.. it's really annoying.. they told me to go to the store.. I am going to.. but still it's very frustrating.. I can't go outside now because of this.. I don't have a Power Bank too... There was no drain issue before this..
This screenshot is from this morning.. the usage is correct.. but the drain is the problem..
soorajrs22march
jithinlal14.jl
What is the name of the launcher
