When asus zenfone max pro m1 android 10 update...?
Hello sir pls answer me...
Y_ASUS
Zen Master I
Hi sthamaraiselvan98,
The latest Android 10 update for ZenFone Max Pro M1 (WW-17.2017.2006.429) can be downloaded here:
ZenFone Max Pro(M1)(ZB601KL) | ASUS Global
janmerocampo
But the latest A10 build has a bad quality sound no bass
Y_ASUS
Zen Master I
Hi janmerocampo,
Sorry, we've checked with relevant teams about the sound quality. In the meantime, if this is affecting your normal use greatly, you may choose to downgrade. You can find the file and instructions in the description "Version MaxProM1_downgrade_to_9": https://www.asus.com/supportonly/ZenFone%20Max%20Pro(M1)(ZB601KL)/HelpDesk_BIOS/
Thanks for your understanding.
