Unable to find the block settings in phone
The block unblock option from the phone settings has been removed. How to unblock a number?
List is not available as the phone setting doesn't contains the option to access blocked numbers
6 REPLIES 6
dibyarupprk2011
https://zentalk.asus.com/en/discussion/35710/unable-to-find-the-block-settings-in-phone
Seems you have 3rd party dialer like Truecaller
Do this.. tap and hold phone app icon, click i button, set the google dialler as phone app bellow .
It will solve this..
dibyarupprk2011
Thanks bro, it worked 👍
I Appreciate ur response
thegeralt1000
Rising Star I
It's showing bro...
I would suggest you to update your Google Phone, Contact, and message app...
Or clear storage, force stop to app...
Or factory data reset
