Touch issue in asus zenfone max pro m2
rana_vishal73
Rising Star I
Facing multi-touch issue in pubg as touch get freeze when we start firing towards the enemy and we can't move the player
Phone also get freeze sometimes while using.
android 10 beta Firmwareversion 17.2018.2004.424
Y_ASUS
Zen Master I
Hi rana.vishal73,
We suggest that you update to WW-17.2017.2006.429 and check if the problem still appears. 🙂
rana_vishal73
Rising Star I
Y_ASUS
Hi rana.vishal73,
This update is for max pro m1 and I am using asus zenfone max pro m2 as mentioned above in description and their is no update till now for asus max pro m2.
Y_ASUS
Zen Master I
Hi rana.vishal73,
Sorry about the mistake.
We suggest that you troubleshoot the problem: https://www.asus.com/support/FAQ/1037600 Please also try reinstalling PUBG.
If the behavior still appears, please tell us the PUBG version, and show us a short video of the problem. (Please enable "Show taps" in Developer options before you record the video. [ZenFone/Pad] How to enable/disable "Developer options" ? | Official Support | ASUS Global) 🙂
