Sạc pin
pphilips192
ZF Model: ZB631KL
RAM: 3G
Firmware/APP Version: 070
Frequency of Occurrence: Luôn luôn
Rooted: No
APP Name: Pin
60% charge takes more than 3 hoursWhat are the asus technicians doing with the ROMs?
ServiceH_ASUS
Hi pphilips192 Is there a particular game/app which you are using while device is getting charged? There could be some apps running in the background. Did you use official charger? Try charging your device on another circuit. . Do you face this in safe mode too? Long press power button> long press power off option> Ok> you will enter safe mode. Please do not use the device while it is getting charged Thank you for your post.
pphilips192
Selena_ASUS posted on 2019/10/1 13:26 Hi pphilips192 Is there a particular game/app which you are using while device is getting charged? ...
Since pie is losing fast charging already, version 0.70 is the worst version, I used many types of phones and did not need to remind me about how to charge the battery, everyone on the forum talked about the battery version 070 ok
