mono sound is played other music
efri_day
Model Name:Asus zenfone Max Pro m1(ZB601KL)
Firmware Version:QKQ1.WW_Phone-17.2017.2008.432-20200903
Rooted or not:not
Frequency of Occurrence:
APP Name & APP Version (If your issue relates to the app):music player, music stream, youtube
Besides the power amp music player, other music players produce mono sound instead of stereo,even YouTube sounds mono when using a headset.please fix it..===============================
Christine_ASUS
Community Legend II
Hi efri_day
Thank you for your asking. I just tested my device in V432 with cable earphones yet I didn't encounter the same issue. The sound performs perfectly with stereo sound in Youtube. Kindly try some stay-at-home troubleshooting tips below:
1. Change another earphones.
2. Please try to enter "Safe Mode". If the function works well in Safe Mode yet the issue remains out of Safe Mode, please check on any disturbance from the installed 3rd party apps.
3. Also, please try "the Factory Reset"
Settings>System>Advanced>Reset options>Erase all data(factory reset)
Please note that once the Factory Reset is completed, all data, apps, settings and personal information will be deleted.
minamino2021
klingeltonkostenlos.de will be my great recommendation for you
ASUS_Bot
Rising Star II
