Bugs In Asus ZM Pro M1 Android 10 Beta 3
sujanjsr0
Rising Star II
Bugs in Asus Zenfone Max Pro M1 Android 10 Beta 3
Build Number-
(QKQ1.WW_Phone-17.2017.2006.429-20200614)
Bugs Which was also present in Beta 1 & beta 2.and still not fixed in this new beta 3.
1) Sound quality through earphones is still weird. (No bass effect)
2) Setting suggestion is not removable. {E.g-Customize your ZB601KL suggestion in setting} (screenshot attached)
3) Huge gap in navigation button while using android 10 special gesture navigation. (Screenshot attached)
4) Google search widget is not removable.
5) Charging vibration is too loud.
6) no option to desable vibration when unlock with fingerprint.(when fingerprint rejected its vibration is GOOD and Natural but when fingerprint accepts its vibrate like android 9 charge connect vibration and no option to desable it)
7) discharge in idle mode.
😎 something app menu blank.(screenshot attached)
9)in dark mode ,white background in Setting search .(screenshot attached)
10)when i call myself from another phone, its showing call notification after 4 seconds,and then asus rings for only 2 second.(during total 6 second of ringing)
*battery*
When Charging
15%-40% =200mA-400mA
40%-50% =1600mA
50%-70% =1400mA
70%-90% =1000mA
90%-95% =400mA(showing Rapidly charging )(screenshot attached)
95%-100% =300mA-400mA (Not rapidly, Normal charging)
Battery backup is good.
How to Fix sound problem temporary:
for sound problem though earphone - use poweramp app-set output Hi-Res Outout-select Sample rate 384kHz then restart your phone and quick play any song from poweramp through earphones.and turn the bass knob to full in Poweramp app equilizer. (Now you will have good sound quality only in poweramp app )
41 REPLIES 41
saurabhbhola80
This screenshot taken from my asus zenfone max pro m1
Sound is disturbed sound not proper bass is ok sounds vibration is coming
Aslam_Basha
Please Focus on this Issue/Bug, that it continuously repeating from Android pie of version WW_16.2017.1912.060 to Present Android 10, and why it can't gone or why you can't solve it, that without I use that application, when I reboot my device it shows "Downloading" Notification, that I can't kept anything download.Now/Present this is Happening in My device of version Android 10 Beta 3 of WW_17.2017.2006.429, and also don't give any trouble shooting steps just fix it. And Last my Opinion is that some apps are running in background silently like this and ony out of 100, Only 1% of me is observed.
sujanjsr0
Rising Star II
manojreddy.budati
https://zentalk.asus.com/en/discussion/31390/bugs-in-asus-zm-pro-m1-android-10-beta-3
Bug 3 is not a bug. After 75% battery voltage will decrease to make sure battery life is good. For devices with Qualcomm processor with Quick Charge 4 (except OnePlus, Oppo, Realme chargers), devices after 75% will decrease battery voltage for better battery health.
When Charging
40%-50% =1600mA
50%-70% =1400mA
70%-90% =1000mA
manojreddy_buda
Rising Star I
sujanjsr0
https://zentalk.asus.com/en/discussion/comment/94319#Comment_94319
When Charging
40%-50% =1600mA
50%-70% =1400mA
70%-90% =1000mA
That's fine. Google and Qualcomm did this for providing better battery life. No need to worry about it.
victor010
Zen Master III
Hi there, thank you for highlighting the issue. We have made a note of the feedback and will share it with the relevant team.
