12-27-2019 01:07 AM
12-28-2019 01:55 AM
02-07-2020 09:09 AM
02-07-2020 10:56 PM
zenRS_victor posted on 2020/2/7 22:39 Hi, when you say that your SOT (Screen on Time) has gone down, can you share the SOT after trying th ...As it can be seen in the graph attached below. WakeLocks and Screen On Time are inversly related. When the Screen is On, there are no Wakelocks and vice versa. I don't have any battery draining apps installed (I'm 100% sure about this), neither I have installed battery saving apps and out of the apps installed, most of them are Force Stopped using Greenify. Note: Reading this might hurt you. But it's not my intention. 1. This doesn't make any sense. I've already Power Saving Mode. Its useless. Battery drain is unaffected. 2. I think its better to use a feature phone then. Why do people use Smartphone then. 3. It has nothing to do with idle battery drain. I guess you know the meaning of "idle". 4. Its such a shame too see you recommending Boost Memory thing. I didn't expected this. 5. There no point in it because Stock Android doesn't have anything called auto start manager.
