Asus zenfone Max pro m1 SD card can't move the file
muthum570
Im facing sd card write access problem can't move any files to sd card couldn't move file error unknown
28 REPLIES 28
arjit_pal199
muthum570
Sd card worked android 9 and android 10 beta 407 and 424 build im facing this problem is 429 build
Wipe data /factory reset and wipe cache on the BIOS
Christine_ASUS
Community Legend II
Hi friends
For anyone who has encountered the issue of files can't move in MPM1, please update the latest version WW-17.2017.2008.432 first, which is now on our official website, please visit our website for manual update
https://www.asus.com/supportonly/ZenFone%20Max%20Pro(M1)(ZB602KL)/HelpDesk_BIOS/
#Update Guide
https://www.asus.com/support/FAQ/1009748/
If the issue persists, kindly reply me as below
1. Which SD card brand are you using? Please provide me the model link of current SD card.
2. Do other SD card brands work in your device on V432 or not?
adeepbarmon50
Hi I'm from India. Dear asus company main bohot dukhi hun kyun ki. Other mobile company ko dekhlo. Almost 90% mobile main Android 10 update agya Yeh 𝐙𝐞𝐧𝐟𝐨𝐧𝐞 𝐦𝐚𝐱 𝐩𝐫𝐨 𝐌1 abhi tak Android 10 nehi aya company kya karha hai. Very sad
RadeonPS
Rising Star II
adeepbarmon50
I hope this is not affecting your work/studies. Because applications work almost the same. Dont be sad over phone updates. Install GCAM and capture beautiful photos if you want. Join zenfonephotography telegram channel.
dibyarupprk2011
Rising Star II
Anandu
https://zentalk.asus.com/en/discussion/comment/118048#Comment_118048
Why are you stating yourself as a lawyer of Asus??
Are you getting paid for this?
Why shouldn't one question about the software updates not provided by the oem in due time as promised, whereas other oem within the same price range are fulfilling their promises!!
