07-15-2021 05:05 AM
07-16-2021 12:45 AM
suchit9x@suchit9xPlease tell us some basic information before asking for help:
- Model Name: ASUS_X01BDA (Max pro m2)
- Firmware Version:
- Rooted or not: no
- Frequency of Occurrence: past 3 days
- APP Name & APP Version (If your issue relates to the app): no
- Build Number: PKQ1.WW_Phone-16.2017.2011.105-20210108
- Android: 9
Hello Team,
I use the phone often, purchased around 2 years back. It never discharged so fast. But in last 3 days, it discharges very fast. If I sleep with 30% charge, after 8 hours the charge reaches 5% (i kept my data and wifi off). I use dark mode always.
Part of t-shooting, i updated all app, uninstalled unnecessary apps, restarted the phone. Still battery discharges very fast.
Can you please suggest a solution
ASUS MAX PRO M2 battery discharge issue
07-16-2021 01:29 AM
07-19-2021 11:57 PM
suchit9x@suchit9xThanks for the update, but I have used ASUS and other phones as well, but even if it is related to battery ageing issue, the battery suddenly does not start discharging so fast. The discharge time reduces with time. We can understand when it slowly start giving less backup. But never got a battery ageing situation where it discharges in a day.
Can you please check if it is related to any updates from ASUS or if it is happening at a global level for all other ASUS max pro series. I do see few more discussions on the same topic. So, may be it is not battery specific, but relate to the software.
07-21-2021 08:44 AM
Falcon_ASUShey mod can you let me know when your team are released stable Android 10 update on Asus Max Pro M1 device ??https://zentalk.asus.com/en/discussion/comment/176743#Comment_176743
According to your description "uninstalled unnecessary apps, restarted the phone. Still battery discharges very fast." If the battery drain caused by third-party app software is excluded, the cause of the problem may still be biased towards battery aging. Sorry for any inconvenience it may be caused.
