Battery drain by (others)
armgev88
Im updated my phone to android 13 (version .73)
In battery section i see (others) tab and like 13% or even 20/21% usage by (others) in the end of day (14% battery left) is it normal???
6 REPLIES 6
Mansi_ASUS
Hey @armgev88, can you please share a log file for the same?
1. Open “Calculator APP”
2. Enter “.19595+=”
3. Select the Log type according to the type of issue you want to capture. “General cases” will work for most issues.
4. After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5. Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
You can share the file with me via PM.
ZenBot
Community Manager
Community Manager
