Back double tap issue - only works sometimes
Tomy90c
Rising Star I
Model Name: ZenFone 9 16/256GB
Firmware Version: VW_32.2030.2030.26
Rooted or not: No
Frequency of Occurrence: unpredictably
Double tap on the back only sometimes works even without the back cover of the phone. When I need this function to work, most of the time the phone does not respond at all even after tapping hard on different parts of the phone.
8 REPLIES 8
Mansi_ASUS
Alright, I've forwarded the issue to the R&D team.
Tomy90c
Rising Star I
Mansi_ASUS
@Mansi_ASUS Thank you
Mansi_ASUS
Hey @Tomy90c, I heard back from the R&D team. They require the following information to conduct a further investigation-
A video recording of the tapping method
Log details
You can share these details via PM.
1.  Open “Calculator APP”
2.  Enter “.19595+=”
3.  Select the Log type according to the type of issue you want to capture. “General cases” will work for most issues.
4.  After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5.  Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
Note: When you're no longer planning on logging your device, enter “.09595+=” in the calculator and the log tool will stop as well as deleting all stored log files. Make sure to share via calculator. The files found in internal storage -> asus_log are not the correct files (they are only 1.2kb)
ASUS_Bot
Rising Star II
