01-23-2022 05:47 PM
01-28-2022 05:55 AM
02-02-2022 02:13 AM
Irene2_ASUSI tried everything... Also the SIM card on slot 2 is not working in the slot 1.Hi @dantnt
Does it happen only one slot 1? The second slot is working fine?
Also did you try with a different sim card?
02-02-2022 04:00 AM
dantntTry swapping the preferred data services to the other Sim card,as in if you are using Sim slot one for data swap it to slot two, leave the Sim cards as they are just swap the data services and see what happens.https://zentalk.asus.com/en/discussion/comment/202913#Comment_202913
Just to let you know, since I wrote this post, it has not happened until today. And now I'm obliged to use the "foreign" SIM card...
02-02-2022 07:28 AM
RoystoysAfter the first slot stops working I don't get any signal. The phone just thinks I have only the second sim installed. Therefore I can select, of course, only the slot 2 as preferred data services (If you mean that option in the "sim card" settings menu).https://zentalk.asus.com/en/discussion/comment/203213#Comment_203213
