How to enable unknown sources for any applications for Zenphone 6 android 10.0
hillmnbvexs
How do I populate the list with more than the nearly useless 5-6 apps on the unknown sources permissions page?
Just about every android on 10.0 lets you select any app on the phone, but the Zenfone 6 doesn't for some reaosn? Is there any way around this at all?
getjohnalive
Rising Star I
To enable unknown source, you have to go to app and notification and special app access. there you will see; install unknown apps.
