11-20-2020 06:24 AM
12-31-2020 05:23 AM
AbhinavDid you tried cleaning your speakers anytime? If so how did you do that? And if not try to do that and check if there is some diffrence coz muffled sound or low sound can happen due to dust accumulated in speaker ports try to blow some air via blower but br careful and see what happenshttps://zentalk.asus.com/en/discussion/comment/143652#Comment_143652
I'm also facing the same issue. My 5z main bottom speaker has lower sound than my friend's 5z main bottom speaker. Did everything. Did reset too. I disabled the audio wizard too but don't know why when calling in speaker mode my friend's 5z main bottom speaker has better vocals than my 5z bottom main speaker.
Overall sound signature is also bad in my 5z speakers if compared to my friend's 5z. My friend's 5z has loud vocal and my phone is has high bass muddled sound output. His phone's speaker is also clear and distors lesser than my phone's speakers.
Don't know if it a problem with my phone's speakers or maybe there is some sort of major bug with audio wizard which hasn't been rectified by the developers Yet. And I also don't know if mods know this too and not especially for 5z. 🙄🙄🙄
12-31-2020 11:06 PM
amitgarde3Nothing happened. Tried everything.https://zentalk.asus.com/en/discussion/comment/143893#Comment_143893
12-31-2020 11:11 PM
ScoooI use Poweramp pro maybe it messed up with any internal device settings. Maybe be.https://zentalk.asus.com/en/discussion/comment/143893#Comment_143893
So, I was able to resolve the problem yesterday and to some extent I was becoming convinced that it is a hardware issue, however I was firm that its software. Here's what I did:
- Upgraded to A11, which did not work straightaway.
- Performed a Factory reset, which also did not work.
- After this factory reset though, I toggled various sound features on/ off and then the balance was restored when watching videos, however audio from other apps like Spotify was stilled biased towards the upper speaker.
- Played around more with the audio settings and the ringtone volume seemed to have returned to original loudness, other audio however remaining the same.
- I went to bed and in the morning and gave a try enabling the AudioWizard and everything seemed to have returned to normal today.
You can follow some of these steps, I am not sure though if A11 has been released for your 5z. However, you will be able to find packages that will help you roll back to earlier versions on Telegram, Reddit, or XDA, this will work for you if indeed one of the recent patches had caused the issue.
Thanks,
Scooo.
01-01-2021 11:03 AM
AbhinavIt could be possible that your speaker is damaged, which may seem unlikely but is possible if you had set some insane configurations on power amp, however I highly doubt anyone uses their phone speakers enough that they could get damaged.https://zentalk.asus.com/en/discussion/comment/143897#Comment_143897
But after a device reset also my phone's main bottom speaker sounds muffled and high bass like with ample amount of sound distortion.
Maybe it's an hardware issue. If it's an hardware issue then I'll not be able to change the bottom speaker.
Yes my phone has also sound output majorly comes from earpiece speaker. The earpiece speaker is very dominating than my phone's main bottom speaker.
I didn't noticed any difference or perceived until I heard my friend's 5z speakers.
01-02-2021 01:05 AM
ScoooActually I don't remember how my phone's speaker was in Android pie or in any other older version of Android. But what I can definitely say that my phone's bottom speaker sounds lower than my friend's 5z's main bottom speaker.https://zentalk.asus.com/en/discussion/comment/144030#Comment_144030
In my case, the sound was extremely low but not distorted or muffled. Muffled sound can be an indication of damaged equipment.
Have a professional check it out, the original replacement speaker is not very expensive, the job won't take more than 500 bucks.
How old is your phone and are you sure that the speaker has been acting up since the last security patch was installed on your device?
Thanks,
Scooo.
