Zenbook Duo UX482 Audio Out of Sync
wave_zz
System: Zenbook Duo UX482
Battery or AC: Both
Model: UX482EG
Frequency of occurrence: Always
Reset OS: Yes, tried three times.
Screenshot or video:
Detailed description:My Zenbook Duo UX482 (i7, 32GB RAM, MX450, Windows 10 Pro) has had an audio out-of-sync issue since day 1. I tried reinstalling windows 3 times and downloading all the latest windows updates but nothing worked. The issue occurs when playing any video, where the sound is always lagging behind (out of sync with speech).
I suspect that perhaps it has something to do with the video card drivers because the problem persists even when I plugged in an external USB sound card and used my headphones.
Also, the video appeared to lock up when I used Google Meet for a video conference this week. Please help!
4 REPLIES 4
Blake_ASUS
Community Legend II
Hi Wave,
The issue happens with built-in speaker, plug in headset or bluetooth audio device? or all?
Can you share a video record of the issue?
Please check your BIOS and audio driver version as well.
potatosubwoofer
Rising Star II
I actually have noticed this problem as well (it is an intermittent occurrence I think). There are a number of users on Reddit also messaging me about this issue and I think it needs to be looked into @Blake_ASUS
It happens on speaker and bluetooth. Not sure about plugged in, but some users have said to me it is also lagging on headset and via USB soundcard
Blake_ASUS
Community Legend II
potatosubwoofer
Hi there,
It would be great if you can share a video or audio record so I can test and compare them.
potatosubwoofer
Rising Star II
@Blake_ASUS I can't do a video recording because the capture device will be out of sync as well introducing errors in the measurement. What I did do however is the following youtube test: https://www.youtube.com/watch?v=ucZl6vQ_8Uo
With audio enhancements disabled there is no detectable delay.
With audio enhancements enabled I can see a 50-200ms delay which is very noticeable.
