UX5406SA zenbook bypass charging
moregrey
Does UX5406SA zenbook support bypass charging ie charging battery to 80% then working off AC?
1 ACCEPTED SOLUTION
Accepted Solutions
Falcon_ASUS
@moregrey
ASUS laptops come with the "ASUS Battery Health Charging" utility, which can be used to set battery charging limits to prolong battery lifespan.
For more detailed information, it is recommended to refer to the following:
ASUS Battery Health Charging - Introduction
Falcon_ASUS
@moregrey
many thanks!
