"ASUS recommended" power plan is missing
akunh1000
System: win 10 64bit
Battery or AC: Battery
Model: ux425qa
Frequency of occurrence:
Reset OS:
Screenshot or video:
Detailed description:
akunh1000
There is an installation file for asus recommend power plan?
Falcon_ASUS
akunh1000
@akunh1000
Since I can't understand the text content of your picture. According to your description, I might suggest you try to update the system to the latest via Windows Update and see if the problem improves. Thank you.
potatosubwoofer
Rising Star II
Hey I did have a similar issue, but it came back magically when changing power modes a couple of times (including looking at the advanced power plan settings)
It could have been an update fix or possibly it just gets hidden by some bug and then it can magically come back. Try using the screenpad plus button above the trackpad to turn the screenpad plus off and then on again and see if that helps? I don't know if it would but it is something that I did around the same time as the problem being fixed.
