Power outage while BIOS updating
flameDust
I was trying to do a BIOS update on my asus zenbook s14 laptop, but my power went off. It looked like it got stuck on black screen so i tried to restart it. Now its s tuck on some sort of bootup process. The keyboard lights and fans turn on, but after a few senconds everything turns off and then it automatically loops again.  Can i salvage this or is the motherboard broken?
Falcon_ASUS
@flameDust
It is recommended that you refer to the following FAQ for troubleshooting.
[Notebook/AIO] Troubleshooting - Computer occurs black screen when the BIOS update process is interr...
If the problem persists, I would suggest you bring back your laptop to our service center for further confirmation.
