Does Zenbook duo 14 OLED (2022) need a screen protector?
FongPoui
Rising Star II
System: Windows 11
Battery or AC:
Model: UX8402ZE
Frequency of occurrence:
Reset OS:
Screenshot or video:
Detailed description:I purchased a Zenbook duo 14 OLED nearly a month ago. I would like to know if it needs a screen protector? If yes, which type?
8 REPLIES 8
FongPoui
Rising Star II
@vanajvidyan
Mine is a Focus tempered glass.
I decided to apply it to the two screens. That helps avoid the reflections.
potatosubwoofer
Rising Star II
That's fantas
FongPoui
@vanajvidyan
That's excellent. I am seriously considering buying one. Do you regularly run the laptop under load?
I occasionally game with an EGPU causing the CPU to run at maximum power so I am worried if the screen protector will begin to peel due to the fans blowing the exhaust up into the main screen. If it can handle this fine then I will definitely click "buy" on a set!
FongPoui
Rising Star II
@potatosubwoofer
In general, a screen protector can be replaced after 1 or 2 years.
ASUS_Bot
Rising Star II
