Asus Zenbook Windows 11 Battery Problem
E_B_543
After installing Windows 11 on my Asus Zenbook, I encountered a battery problem. My computer does not work on battery and sometimes my computer suddenly shuts down even when plugged in. I uninstalled the update but the problem did not go away. I checked my battery and it is fine. However, I cannot use my computer on battery. It happened right after the update, there was no such problem before. When I researched, I read that other Asus users also have the problem after installing Windows 11.  Could you help me with the situation?
E_B_543
@E_B_543
Based on your description, it may be caused by battery aging or malfunction. It is recommended to take your laptop to a service center for further inspection.
