My m6500qc had the 4th motherboard in 3 years. Why does it keep breaking down?
Szonja
Hi yall,
I try to make myself clear, cus it is my second language.
My laptop was on it's 3rd guarantee service visit since I bought it. They do not do anything else just change the motherboard.
It just die out of the blue and had a squeaking noise (as you can see in the attachment). It is black and does not reply to any movement except if you push the middle of the keybord it stop and you can turn it on till you move the laptop again than the same scenario.
It does not overheat, no noise just dies and only the motherboard change can solve it according to the service.
But 4 motherboards have died in my asus in 3 years. Is it normal?
Thank you for your help! :3
0 REPLIES 0
