02-14-2022 01:59 PM
02-14-2022 02:25 PM
02-14-2022 10:08 PM
tpnowak@tpnowak
- System: Windows 11
- Battery or AC: both
- Model: N7600PC
- Frequency of occurrence: always
- Reset OS: yes
- Screenshot or video:
Detailed description:
I experience an issue with audio on my new Vivobook Pro 16X. The audio volume level is very low, even at 100%. I tried switching to headphones for testing purposes but it did not help. Never had such problem with any laptop. I assume some background app for microphone is lowering the volume level.
Regards,
Thomas
ASUS Vivobook Pro 16X - low volume on both speakers/headphones
02-16-2022 04:21 PM
Falcon_ASUSAlready tried reinstalling audio drivers. Many times.What are the system version, BIOS version and audio driver version you are currently using?
Have you tried removing and reinstalling the audio driver?
02-16-2022 06:33 PM
tpnowak@tpnowakhttps://zentalk.asus.com/en/discussion/comment/204542#Comment_204542
Windows 110. BIOS version 3.00. Right now using the ones from ASUS website - 9231.
