2 weeks ago
I have recently bought Asus Vivobook pro 15 q533mj. I am facing severe heating problem. on normal usage it is hitting up to 70 -75 degrees which is not normal Also I am not able to control fan speed. I think they are automatic and only turns on when the temperature is above 60-65.
What should I do now?
#Vivobook #Asus #support Asus VIP membership
a week ago
@Pratik2
I think this is normal, especially when using the laptop for general tasks or moderate workloads during summer or in a stuffy environment.
I would recommend checking whether your system and BIOS are both updated to the latest versions, or you can try elevating the back of the laptop to improve airflow underneath.
[Windows 11/10] How to Use Windows Update to Update System and BIOS
[Windows 11/10] Troubleshooting - Overheating and Fan issues
If you still feel that the device is overheating, we suggest bringing your laptop to a service center for further inspection.
