em
09-23-2020
08:44 AM
- última edição em
01-16-2024
12:43 AM
por
ZenBot
em 09-23-2020 12:12 PM
ANDΞRSONIf it not popped up, then you can move the downloaded file into memory card and reboot your device into recovery mode and choose option "Apply update from external storage".https://zentalk.asus.com/en/discussion/comment/116812#Comment_116812
I already did that you said nothing, I think this version has a problem my version QKQ1.WW_Phone-17.2017.2006.429-20200614
em 09-23-2020 12:16 PM
YachendraEu já baixei o mesmo arquivo 2x, só não testei por microsd.https://zentalk.asus.com/en/discussion/comment/116815#Comment_116815
If above step also not working then there will be issue with the downloaded file. So, re-download the file again without any interruption and try again.
em 09-23-2020 12:17 PM
YachendraI've already downloaded the same file 2x, I just haven't tested it by microsd.https://zentalk.asus.com/en/discussion/comment/116815#Comment_116815
