em
02-08-2021
04:42 PM
- última edição em
01-16-2024
01:05 AM
por
ZenBot
em 02-10-2021 08:40 AM
isaias.roberto.2008Bro try to do one factory reset and check it if again face problem then try to change DPI settings in developer option or else not problem solved check it out to service center.Please tell us some basic information before asking for help:
- Model Name: Zenfone Max Pro M1 (64GB/4GB)
- Firmware Version: QKQ1.WW_Phone-17.2017.2012.438-20201203
- Rooted or not: Not
- Frequency of Occurrence: Ever
- APP Name & APP Version (If your issue relates to the app):
Hi guys. I'm new here, I ended up creating this account to find out if someone can help me. The problem is very "simple", whenever I'm playing (usually FPS games) delays happen when touching the screen with multiple fingers. An example is when I am using the left part of the phone to move the character, while the right moves the crosshairs. When using both simultaneously, the crosshair moves about 1.5 to 2 seconds late. Does anyone know how to solve? This only happens with multiple taps. Thank you all!
Touch Lag Max Pro M1 (64/4GB)
em 02-11-2021 02:31 PM
santhosh05092001Thanks, the factory reset already tried (by accident lol), I will try to change the DPI. The problem started after Android updates (9 to 10), I expected it to be a software problem but no one reported. Bad luck for mehttps://zentalk.asus.com/en/discussion/44581/touch-lag-max-pro-m1-64-4gb
em 03-17-2023 03:36 AM
