Power master doesn't work
Saprosi
Hi guys. I'm new here. As in the title even if I set the period in the battery care of power master it doesn't work and the phone goes in hyper charge. I had tue same idsie with android 9, I thought it had would been fixed with the update but it's still not working. Suggestion? Thank you
zeruel_tenshi
Rising Star II
Mine works fine and it does go to hypercharge using the 30watt charger. It just stops at 80% and gradually rises up till 100% at your set end time.
Anders_ASUS
Hall of Fame III
Saprosi
Try clearing the storage of your power master app. system settings -> apps & notifications -> see all xxx apps -> press show system in top right corner -> search power master - Storage & cache -> clear storage
