10-03-2020 12:09 AM
10-03-2020 08:22 PM
10-03-2020 08:33 PM
azwadrabWell if you are not facing anything you are lucky.Nope not facing any of this
Do a clean factory reset to see the problem still exists or not.
In this update battery drain is fixed(turning off mobile data/wifi for the whole night)
10-03-2020 11:25 PM
yaduwanshishubhamActually what I do is whenever a new update arrives.https://zentalk.asus.com/en/discussion/comment/121230#Comment_121230
I cannot do factory reset everytime if some issue is occured. I am just fed-up that something is wrong just factory reset the phone. The only solution they have first factory reset then see if the issue is still present. This is not possible everytime, instead they can provide optimized software support but they are failing.
10-08-2020 11:11 AM
