12-24-2021 02:50 AM
12-28-2021 03:15 AM
VENU S NWould u please dont mind posting it here as well?https://zentalk.asus.com/en/discussion/comment/198812#Comment_198812
https://us.v-cdn.net/6031231/uploads/I7WGARKW9WNP/vid-20211227-092839-t.mp4
I tried my best to record the video during the issue from other phone Also some times even if I tap once on screen ghost touch triggers and does triple tap or beyond that.
SwarajMods here says if we need features or bug fix we have to post it in "ideas for next"Am listing down the problems to be fixed and features to be added for users simplicity.
Am on latest firmware i.e .190 (A11)
- X mode settings in armoury crate doesnt apply to games. For example i have set Pokémon unite game cpu frequency at 2.4 ghz and when i launch game and check, it shows 825 mhz and keeps fluctuating in between 825 mhz to 2.97 ghz. On A10, there was a different problem and i think this is interrelated somehow. On A10 when i setup my xmode to level 1 and cpu at 2.4ghz and when i strt the game and check the cpu freq in game genie, it didnt show me 2.4ghz freq, it was very lower than 1.8 ghz. I.e 875mhz or something. I tried on various games with different xmode levels and frequencies but still the same issue. The only thing that worked was, if u setup xmode level to level 3 then the game genie showed the correct cpu frequency which is chosen by user i.e if i select 2.4 ghz it displays 2.4ghz or if i chose 1.8ghz , it displays 1.8 ghz . But for level 1 or level 2, it didnt seem to work properly.
- feature to select and delete multiple contacts.
- feature to turn led light to green when battery is charged to the limit set by user. for example if i set charge limit at 80% then when my phone charges to 80% the led should turn green notifing the user that phone is charged. the current led stays at red and i get confused lots of time thinking that my phone is still charging, making me leave it for a while.
- Virus defination update option in "privacy and security" . Since the option is not there yet, does that mean we dont have an antivirus protection now? bcuz i couldnt find anywhere about avast antivirus being mentioned in privacy and security.
- Surfing Chrome is both smooth and jittery sometimes. Idk whats the problem. It runs smooth at interface but jitters on some web links while scrolling.
- Option to create new blank window on homescreen. Also there is an option to change font color at home screen but there isnt any option available to set it for all apps/app drawer
- Option to hide "battery saving mode turned on" notification and "charging limit set" notification in notification panel. A small icon on status bar is sufficient to notify user about it.
- Ghost Touch appears out of blue. It doesnt occur frequently, but its there. (Am damn sure my hands were dry and clean when it happened). The only solution that works for me is locking and unlocking my phone. After doing this, ghosttouch issue disappears instantly and appears who knows when. This ghosttouch issue is being on rog firmware since a9. And am disappointed to know that its still not fixed. Its impossible to record it bcuz screen gets unresponsive when it happens. I have even logged my phone when it happened on a9 and submitted it. But its still there, way back from a9 to a11.
- Themes are not system wide applied or end to end. Am sure @ARP_ASUS noted it. But what i want to know is even if u fix it, will it really apply on system apps and system hints which still displays in orange theme? despite of any theme chosen??? for example mobile manager app and autostrt manager>Notice, slider in app drawer etc still displays in orange color
- It would be wonderful if there were more live wallpaper animations which react to xmode enabling/disabling.
Thats it. Everything is working perfect for me.
Thanks for buttery smooth A11.
Bugs to be fixed and some necessary features to be added for ROG 2.
