Block touch edge on Rog phone 2 Android 9/10
mocobx
Hi all,
I tried to use the blocking edge feature provided in Armoury but it doesn't work at all. I noticed this on Android 9 and even after upgrading to Android 10 the issue still persist. I tried this feature for COD and PUBG.
Is it happening to me only or every one?
Is sthere a solution to this?
Thank you all in advance
10 REPLIES 10
Anders_ASUS
Hall of Fame III
mocobx
https://zentalk.asus.com/en/discussion/comment/72424#Comment_72424
Thank you guys for replying.
Actually blocking edge is not working at all. It doesn't matter if you have constant touch with thumps or not. The feature dose not block the bottom edges. I believe this issue needs to be escalated and fixed by developers.
Thank you for the support.
Please make a screen recording and be sure to mention me so I get a notification. Record both your settings and the game when playing
