Idle Battery drain &Whatsapp calls not working properly after the A15 update
kirancrazy1
The battery drain is high during Idle time and whatsapp calls keeps get dropped or Mic is off for few mins .
Hope A15 should have been a good update but nope .
6 REPLIES 6
Mattias_ASUS
Hello @kirancrazy1
Are you in the update 35.1210.1420.78?
Thank you for the confirmation, I am sending this information to the devs, will let you know if they have any questions.
I worked on few settings in battery management and I guess Whatsapp is working fine but yet to test for long calls. But battery drain there overnight it drained almost 30 percentage.
