Sound quality issue from speakers
abrarkhan959
Rising Star II
Again in recent update .68 the speaker volume has been drastically reduced and bass is reduced sounds distorted please fix this why is every new update spoiling the speakers sound @Mattias_ASUS
24 REPLIES 24
Also how do I post a video of the distortion voice while playing song
For this you can also create a log while recreating the issue for the devs to look into, you can do this by following the steps down below, and feel free to DM me with the link when you are done.
For the video you can also film it with another phone, if you have another phone accessible.
1.  Open “Calculator APP”
2.  Enter “.19595+=”
3.  Select the Log type according to the type of issue you want to capture. “Sound, call audio, and recording”
4.  After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5.  Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
Thanks for the response, I've DM the sound log please check and let me know if there is anything I can share
Thanks
have you checked audio logs?
Hello @abrarkhan959
I've sent you are reply, the link you sent was private and they couldn't open it, please change it to open to anyone with the link.
