20 hours ago
So my Kunai after 1 year of usage is starting to have issues.
First the flimsy part snapped but that was expected so ignored it but now after 1 month of not using it due to life being annoying as usual when I slide it into the bumper case it doesn't connect.
It randomly does so but pretty much disconnects right afterwards.
I've yet to try cleaning the ports with the metallic circuits to avoid anything catastrophic but Bluetooth is working fine.
Any suggestions on what to do here?
And if it's **bleep**ed and I need to find something to replace it with just to check but does the new tensen controller work on the 7 or is it not backwards compatible?
