Battery Draining at standby mode
xk_FrOst
Hi ASUS Team,
I have been facing battery draining at standby mode, i.e., while sleeping at night and waking up in the morning 🙂 , I have been experiencing this for the past 2 months.  My current System Update version is: 35.0604.0820.68
Last night my phone was charged up to 60% and in the morning whole battery was drained out.
When I checked the Battery usage then it was showing
  • ~95% power consumed by system apps when filter was View by apps
  • ~85% power consumed by CPU when filter was View by systems
Mattias_ASUS
Hello @xk_FrOst
I have sent a similar issue to the dev team, but it would help getting more logs to help them see what could be causing the issue, for this you can follow the steps below and recreating the issue, for this I would advice starting the log and letting it work for around 2 hours. When you are done please feel free to send me a DM.
1.  Open “Calculator APP”
2.  Enter “.19595+=”
3.  Select the Log type according to the type of issue you want to capture. “General cases” will work for most issues.
4.  After your selection the log tool will exit so you can duplicate the issue or wait for it to happen. Try to use the screen recorder to show your issue when possible. If you can't screen record your issue, then please take a screenshot right after the issue has occurred (as a timestamp) so we know where to look in the log.
5.  Navigate back to the log tool via calculator and Tap "FINISH AND SHARE".
Mattias_ASUS
Hello @xk_FrOst
Got a reply from the team and according to the log your issue might be caused by a hardware problem, please reach out to your closest ASUS Service Center for further assistance.
https://www.asus.com/support/service-center-location/
