Fps problem
kimpubg95
Hello anyone can help me i have asus rog phone 6 android 13 and after i updated to android 14 when i play pubgm and codm my fps cap to 90 even set the game max fps /120, xmode+ on game genie set fps 165 .
10 REPLIES 10
OSCARK32
Rising Star I
Here's your solution, unfortunately Asus is not to blame, the fault lies with the game developers who limit the amount of fps you can play, for example CoDM runs at 120fps but in BR only at 90fps,, Now with the root issues on Android 7-6 some have asked to remove that limit with third-party apps or phone modifications, even the ROG 8 is not able to take the game to a stable 120fps, and And increasing the Hz on the screen will not increase your FPS because that is already determined by the game, if it goes to 90 and you set it to 165hz it will not go to that frequency since as I say it is the screen frequency, they are not fps.
I don't think so . Becay last time my android 13 everything go smoothly but after the 14 update not only fps problem it also bug front camera not working .. i want to downgrade to 13 or root access to bypass those fps Cap..
I also getting some errors installation of some app say something like package name conflict
I don't think its the game problem the game not yet push any update before i push to adroid 14
