11-11-2025 12:08 PM
My phone's battery suddenly started draining very quickly even when I'm not using it. What would be the problem?
11-12-2025 03:48 AM
It sounds like there might be something draining the battery.
You can see what could be doing that by going to Settings > Battery > Battery usage > Battery usage since last full charge.
There you can see it by apps or by systems.
11-12-2025 01:27 PM
what can I do.....
11-13-2025 01:55 AM
It looks like some processes are working extra in the background, the best and easiest course of action here would be to do a factory reset to have a clean install of Android without things making them work extra.
Monday
Estou usando a penúltima atualização OTA oficial do site, será que eu deveria atualizar para a WW-35.0604.0820.78, esta será a última versão para o ROG 7?
E depois fazer o clean install?
