BATTERY
silenczio
updated to the max. rog phone 6 pro.
1st- when opening it auto shuts down, doesn't matter if i charged it turned off. if i remove the charger then opened it it auto shuts down,
2nd- when charging even if i drained it, it will show 100%. the only way to open it is connect the charger then open but
3rd- same as 2nd battery display when the phone is turned on it just stays at 100%.
heres other thing, if i charge it for 30mins-1h and opened it, it stays longer so i think the battery still charges to max.
tried factory reset still same. is this a battery fault? or is this fixable please help thanks
0 REPLIES 0
