Rog Phone 5 , fingerprint scanner problem
MiroS
Rising Star I
Model Name: Rog phine 5 12/256gb
Firmware Version: 18.0830.2101.86
Rooted or not: NO
Frequency of Occurrence:
Hi, I have the problem with fingerprint scanner, is very slow ...Sometimes it worked fine, though not particularly quickly. Other times it flat out refused to work ...
Have anybody this problem ?
10 REPLIES 10
uvukee
Danishblunt
The reason for this is because asus opted for a even smaller sensor than last year which already then was meh to begin with.
It isn't bad if calibrated well. Size has nothing to speed of reading, because it reads or not. Sometimes it is just lagging.
Mi 10T have very small fingerprint sensor but it works absolutely stunning (if calibrated well).
Aryan202
Community Legend I
Admin
【Version】
18.0830.2102.88
【Model Name】
ROG Phone 5 (ZS673KS)
【Release Date】
2021/04/21
Since the server pushes update notice to different serial numbers by batches, it may take some days for you to receive the FOTA notice. Thanks for your patience. You may tap “System updates” in [Settings] >[System] to check if there is new firmware available. Or, you can also try to manually update firmware by referring to the following link.
How to update firmware on my phone?
【Release Note】
  1. Android security patch update to 2021-02
  2. Optimize fingerprint recognition
[210412] ROG Phone 5 _18.0830.2102.88
The changelog for the latest .88 ota says optimised fingerprint recognition
Check if it's any better
Some on the telegram grp have reported improved detection after this update
AmitGarde
Community Legend II
MiroS
  1. Model Name: Rog phine 5 12/256gb
  2. Firmware Version: 18.0830.2101.86
  3. Rooted or not: NO
  4. Frequency of Occurrence:
Vedraj
Yes i also have this problem with the fingerprints
uvukee
Finger sensor not working good for me too. I have added 5 fingers of the same finger to make it work better.
And this sensor is ultra slow. Maybe because this animation?
Update to latest firmware version . 88 and problem solved.
Eflong
Same problem using the latest firmware .26 fingerprint sucks
Danishblunt
Hall of Fame I
uvukee
https://zentalk.asus.com/en/discussion/comment/163707#Comment_163707
wrong, if you get dirty fingers a lot then it's useless no matter how much you calibrate it. Typical fingerpring sensor as seen on other smartphones are just so much better.
