06-12-2021 03:56 PM
06-14-2021 03:57 PM
thejus44Thanks a lot. I have a couple of questions, if you don't mind. 😅Here's my usage. I followed the tips from a user "Therazorsedge" on xda:
1 # Disable: "Phone data always active" on developer settings, search on GOOGLE how to access to developer options.
2 # Install latest WW rom from the zip on ASUS website >than .49 and do FULL WIPE.
3 # IF YOU DON'T HAVE 100% SIGNAL ON 5G, DISABLE IT, cause don't work and drain battery.
I'm running build 18.0840.2104.49, by the way.
06-14-2021 03:59 PM
thejus44I haven't installed the WW Rom from website but, I am running the same build as yours.Here's my usage. I followed the tips from a user "Therazorsedge" on xda:
06-14-2021 09:09 PM
06-14-2021 09:31 PM
ReaperzwolfIts the global ROM, I meant I haven't downloaded and installed from the website.@Anna-Kin Is you phone the Tencent version? Are you not running the Global Rom?
Anyways i would still suggest go ahead and get a replacement done asap. Later it would be difficult for you bro
06-14-2021 10:03 PM
Anna-KinSuch type of SOT can be achieved if you barely use your phone and switch off the phone in between. There are gaps in the graph which is phone switched off. So coming to other parts he seems to have just utilised less apps.https://zentalk.asus.com/en/discussion/comment/171673#Comment_171673
Yeah, i guess i ll try to get it replaced.
@Reaperzwolf Just look at jus44's battery usage man. Its amazing. I mean.. how?
I know that isnt the full screenshot, still it has 12 hrs of SOT with browsing, watching YouTube and texting, impressive.
