Aeroactive cooler 3 fan not working but it does rgb and charging
aeron_crestfall
Model Name: rog 3
Firmware Version:
Rooted or not: not
Frequency of Occurrence:
4 REPLIES 4
Irene2_ASUS
Zen Master I
Hi @aeron.crestfallen
Try clearing the storage and cache of Armoury Crate, then reboot your device and try again.
I have same issue....my rog 3 fan cooler cant connect with my phone.....already clear cache and do reset idk what happen
Was there a solution on this? Because I have the same issue with my aeroo active cooler 3. Rgb lights and it's ports are working but the fan does not. I have two aeroo active cooler 3 just bought another one but with same issue. I'm a fan of ROG so Please fix this problem, thank you. very much.
Ashing
The trigger reacts automatically and my fan is unavailable
