My gpu MHz is very low and doesn't go above 1405
lilgreazile
HI, sorry my reply had many mistakes.. This is because I started investigating on this issue 2 days ago. Those 2 days I did a lot of research on this issue but couldn't really find luck. This started when I was playing fortnite and had may drops in fps. after hours of research I found this. as you can see in the following picture there are two white temps in the bottom. one is very high and one is at 70. before I use to have both of these temps high os I got good fps. but now look. on investigating this I will also show u what the rog panel says. As the following video shows that the gpu Mhz is very low but cpu is at acting good performance very high. before when I bought this laptop last year it was both high , I don't really know what caused this maybe a windows update or something . please help
30 REPLIES 30
RAJU_MSC_MATHEM
Zen Master I
go to control panel, then power , create new power plan , select high performance plan give some name , click ok .
lilgreazile
Yes I got the mamange you performance encounters what do I set it to now
lilgreazile
Ok what do I set it to in gou counters all option or restricted option so I can disbale perf limtier
RAJU_MSC_MATHEM
Zen Master I
open the nvidia control panel, at click on desktop tab , put a tick mark in enable developer access
RAJU_MSC_MATHEM
Zen Master I
Perf limiter is different,. Here you enable access performance counter
