Does Zephyrus Duo 16 can using other bland 100W PD charger?
Donghee
System: Windows11
Battery or AC: AC
Model: Zephyrus Duo 16
Frequency of occurrence:
Reset OS:
Screenshot or video:
Detailed description:
I bought a Zephyrus Duo 16 recently. I really like using this laptop.
Powerful, reasonable weight compared laptop specs. But the charger weight is way too heavy and big. And I know the Zephyrus Duo 16 can use 100W PD charger. So I wanna buy a PD charger. But can I use other brands of PD charger? I heard that ASUS laptops only allow the same bland charger if I wanna 100W charging.
Falcon_ASUS
Donghee
  1. System: Windows11
  2. Battery or AC: AC
  3. Model: Zephyrus Duo 16
  4. Frequency of occurrence:
  5. Reset OS:
  6. Screenshot or video:
@Donghee
From our standpoint, we will recommend that you use our equipment for charging. The PD specification is Input 20V/5A; Output 5V/1.5A, the charging may not be fully charged or power drop. Sorry for any inconvenience it may be caused.
ASUS_Bot
Rising Star II
